I have a problem with my dti2.2 2001 Frontera. The battery goes flat.
I have diagnosed the electrical system and found none of the electrical circuits to be causing it. The draw on the battery, when engine is off, is 0.19mA!
I suspect the alternator/dynamo. I don't know where the wire is connected, that goes to the battery. I want to disconnect it, and see if the alternator/dynamo is sucking power and needs to be replaced.
Where is it connected? How can I access it?
cheers
Magnus
